TRIOS Patient Monitoring updates
TRIOS Patient Monitoring — Software updates
TRIOS Patient Monitoring 21.2
November 2021
TRIOS Patient Monitoring 21.2 for Dental Desktop 1.7.27
Available for 3Shape Unite
The latest TRIOS Patient Monitoring features new comparison and communication tools, supported by a revamped user interface for more intuitive use, easier navigation, and more engaging visualizations.
Ruler for Scan Measurements
The addition of a ruler tool allows you to place linear measurements directly on the scan to measure the distance between two selected points on the scan. The placed measurements can be used in conjunction with the "snapshot" tool to support documentation and communications.
Comparison Slider
Swipe the slider to compare two selected scans and see the changes between them with an easy and intuitive visualization tool that is sure to impress your patients and enables you to focus on a specific area of interest.
Comparison Slider
Revamped left panel interface
The design of the left panel has been revamped to support touch screen users and provide faster and easier access to the full toolkit available within TRIOS Patient Monitoring. You are now able to collapse each category within the left panel and free up screen space when needed.
Snapshot folder path with automated file naming
In the TRIOS Patient Monitoring settings, you can specify where snapshots taken within the software should be saved. The snapshots taken will automatically be named on the basis of which tool is in use and organized into patient specific folders.
General Improvements
Use the < arrow > keys on the keyboard to turn the simulation into a “slide-show”.
3-Point alignment sub-windows are now easily resizable for touch screen users using the “vertical enlarge” button ⭣▯.
Previously selected tooth in the “tooth cross section” is pre-selected upon re-entering.
Known Issues
Automatic Segmentation optimized for dentition without brackets
Scans with large brackets may not automatically segment properly, though it is possible to use the manual segmentation tools to do so.
Simulation does not support partial scans or scans with brackets
Similarly, the simulation feature is not optimized for morphing scan sets that contain partial scans or scans with bracket.
PREVIOUS UPDATES
Model Maker updates
Smile Design updates
Improvements and changes in the Smile Design software.
TRIOS Treatment Simulator updates
Improvements and changes in the TRIOS Treatment Simulator software.
This page includes new features, some of which may not be available in your market.
